Gracias Gracias:  1
Me gusta Me gusta:  1
No me gusta No me gusta:  1
Resultados 1 al 5 de 5
    Usuario Nippon México Avatar de Deno
    03 Jul, 11
    Obregon City
    253
    Codigos de motor SR20's
    Hola compañeros,siento que esta info no esta en el foro,todo sobre SR20's.
    Head #'s
    1N5 V1 - SR16VE
    1N5 V2 - SR20VE
    5J -
    51N -
    52F - Larger Exhaust Valves Silvia engine
    53C - JDM Pulsar GTi-R. 8.3:1 T28 Turbo Low Imp. 444cc Injectors Larger Top Mount Intercooler Larger Oil Cooler Solid Lifters Ind. TB's Oil Squirters
    53J V1 - USDM Black Channel Valve Cover Highport 9.5:1 1990-92 Red Injectors EGR OBD-1
    53J V2 - 1R USDM Silver Valve Cover Highport 9.5:1 Red Injectors EGR OBD-1 1993 RIBS
    53J V3 - 5R JDM Ribs on head Silver Valve Cover Red Injectors Mitsubu Alt. tubular ex. manifold 1/1 in circle and /5 in circle on head beside 53J
    53J V4 - JDM Black Channel valve cover
    53J V5 - JDM Silver Valve Cover No Ribs
    53J V6 - BlueBird SR20DET 8.5:1 sodium filled valves 7mm stem Oil Squirters T25 Turbo High Imp. 370cc Injectors Top Mount Intercooler Oil Cooler Hydraulic Lifters Single TB
    53J V7 - JDM Black Channel valve cover tubular ex. manifold 10:1
    53J V8 - 2L W11 Avenir 8.5:1 silver valve cover Ribs 370cc purple injectors T25 ball bearing turbo Big TPS No EGR Mitsu altenator High port Internal coil OBD-I Stock oil catch can steel pipe has a built in restrictor.........the one the runs from the valve cover forward then behind the distributor to the stock catch can. same BOV/CBV as teh 1stGen DSM
    53J V9 - W10 weaker BOV then the W11 Non ball bearing turbo 8.5:1
    53J V10 - 3L 10:1 JDM bare aluminum cover w/ black in the middle No Ribs under the coil there is a circle with a line through it and a small number 7
    53J V11 - 2R I think this is a W10 BlueBird SR20DET 8.5:1 sodium filled valves 7mm stem Oil Squirters T25 Turbo High Imp. 370cc Injectors Top Mount Intercooler Oil Cooler Hydraulic Lifters Single TB Red V/C black channel
    53J V12 - 3L JDM Ribbed head, All silver valve cover, either a 6 or 9 and a 1 in circles under the coil.
    53J V13 - 8R JDM with an 8 in a circle behind the coil bare aluminum vc tubular header external coil and egrless of course highport ribs on the side of head
    53J V14 - 8L USDM Ribs 93 NX2000 All Silver Valve cover 9.5:1
    54C - N14 Pulsar DET
    54D -
    58Y - SR18DE JDM highport.
    64J - SR18DE SR18Di JDM lowport.
    65J - 2R 2J2 10:1 JDM Silver valve cover
    78E - BlueBird SR20DET (53J Head) Larger Exhaust Valves
    79E - Larger Exhaust Valves
    89H - SR20DE Silver Valve Cover U.K. '94 SLX P10 lowport No ribs 9.8:1?.
    89J - SR20DE Red Valve Cover UK lowport sodium filled valves 10:1 Gray 259cc Injectors .
    94Y V1 - 3L SR20DE US lowport 9.5:1 OBD-1 1994
    94Y V2 - SR20DE US lowport 9.5:1 OBD-2 1995-99
    96J - 1R UK Redtop 10:1 Highport (UK 101 1R 96J head)Gray 259cc Injectors Mitsubu Alt. sodium filled valves
    Unknown - USDM B15 Roller Motor Nonpainted VC 9.5:1 OBD-2
    Unknown V1 - AUTECH 11.5:1 175hp for Lucino Nonpainted VC
    Unknown V2 - AUTECH 11.5:1 180hp for Primera Nonpainted VC
    Unknown - 53J 4R, JDM 53J 3L, 53J 1R McRib USDM, 53J 4J???, 53J 4L
    espero y les pueda ayudar en dudas sobre el motor que tiene.
    Saludos.
  2. Thanks Vfrausto thanked for this post
    Likes Vfrausto liked this post
    Dislikes Vfrausto disliked this post
  3. #2
    Apoyo al foro Nippon México Avatar de import solutions
    02 Mar, 11
    colima
    1,642
    excelente informacion
    import solutions
    Hidden Content
    importacion de todo tipo de piezas y refacciones automotrices
    xv40 proyect loading
    servicios de logistica e Importacion de todo tipo articulos eua,canada ,asia " ebay,amazon,best buy entre otras tiendas americanas"
  4. #3
    Hacia falta este temita, lo marcamos como importante, tienes rep deno, saludos.
  5. #4
    03 Jul, 11
    Obregon City
    253
    Gracias compañeros eso mismo pense yo,falta esta info en el foro,y buscando informacion acerca de mi sr20's me encontre con este y me fue muy util.
    Saludos.
  6. #5
    Camicab
    el b14 de condo miembro e aqui del foro monta una de estas chuladas
  1. Motor VR6
    Por Herrera en el foro Vag, Mopar, Muscle Cars & Otras marcas
    Respuestas: 24
    Último mensaje: 25/04/2012, 09:30
  2. Inyectores SR20's
    Por Deno en el foro Modificaciones al motor N/A & Turbos
    Respuestas: 9
    Último mensaje: 28/03/2012, 21:40
  3. Códigos de Partes para SR20
    Por Viktor en el foro El taller mecánico
    Respuestas: 12
    Último mensaje: 05/11/2011, 14:34
  4. Códigos de Error de ECU SR20
    Respuestas: 17
    Último mensaje: 18/10/2011, 06:08
  5. Neo VVL all motor 12.91
    Por Ferri en el foro Videos
    Respuestas: 14
    Último mensaje: 11/05/2011, 07:23
Thread Participants: 2
